3/8 Nylon EFI fuel line extra.
TrailBeast
AKA Mopars4us on Youtube
Arizona
Before long I'm going to be replacing the entire factory steel 5/16 fuel supply side line with FI nylon and using the OE steel as a return.
Going to use the OE supply connection on the sender for the new line and install a fitting in the fuel filler tube for the return
I had to order a 25 foot roll of the line and will have about half of the roll left when I'm done if anyone might be interested in buying the other half.
OD is 3/8 and ID is 5/16.
This is the stuff.
555-159236 | Jegs High Performance
