3 inch exhaust clearing gas tank 70 Dart ???
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
I've read posts about Getting clearance with 70-72 Darts (111 inch wheelbase) having clearance issues around the gas
Tank with 3:inch exhaust, running the pipes as straight as possible out the back of ????
comments ???
tti 3 inch
I have 3" TTI on my 69 Bcuda. Had to bend the corner of the tank up a bit otherwise they fit like a glove!
I've got 3" tail pipes with a mini tub and I boarded springs. It's doable but took me forever to make them.
3 inch inboard kit and 29 14.5 tires on 12 inch wheels. I used the factory tip hangers in the factory holes on the side of the rail using an aluminum spacer and a longer bolt.
