Johnny71dusty
Been looking on eBay and cl around the country for a few weeks and nothin
Like I said, let's wait and see. They wear and get out of adjustment, but they really seldom....and I mean SELDOM break. So let's see if we can get you going.Balls
I agree. I think the adjustment is his only issue. Maybe my video showing how it works correctly will help. I have it uploading to youBOOB right now.I just watched your video. I noticed 2 things.
First, you need to get that front lever (1st-rev) up to the neutral position or the cross-over blade will never grab it. Follow the instructions in the FSM.
Second, that small screw near the firewall needs to be tightened down. It should not be moving back and forth in the slot. That is the adjustment to take up slop in the mechanism. The inner collar is rotated to adjust clearance. IIRC, my 64 had 2 slots with screws, yours may only have one. You seem to have a lot of clearance between the various parts.
I have to leave for awhile and get back to work on my 4 speed conversion. Good luck!
Thanks so much , this does help . Mine is broken internally I guess . Took off all linkage and forced the blade onto the 1/r arm and it would go to reverse up but not down to 1 stI said "steering linkage" since I was staring at the steering column, but of course I meant shift linkage. LOL
Yes - linkage is off and I used a wrench to click it to neutral and started the car to verify . Second I put Linkage and arms back together on Column , leaving rods at trans loose and only tightened after forcing the to arm to be equal and forced the blade down on to the 1/r arm and it would go to r and back to n and to 2&4 now but won’t go to 1 . Took that arm loose is goes limp to ground . My column won’t move blade hooked up or not to down 1st position not matter what . This mixes with just broke my second hood just killed driving this build this year or seemsHave you tried connecting the linkage to the transmission and putting it in neutral AT the column linkage? It will need to in neutral at the transmission, too. I know up to this point, you've said it was disconnected at the transmission, right?
And hay, it's not the end of the world if it id broken. If you do confirm that, get the column out and get it apart. It's not a difficult system to repair.
I think at this point, I would get the column apart.Yes - linkage is off and I used a wrench to click it to neutral and started the car to verify . Second I put Linkage and arms back together on Column , leaving rods at trans loose and only tightened after forcing the to arm to be equal and forced the blade down on to the 1/r arm and it would go to r and back to n and to 2&4 now but won’t go to 1 . Took that arm loose is goes limp to ground . My column won’t move blade hooked up or not to down 1st position not matter what . This mixes with just broke my second hood just killed driving this build this year or seemsballs
Anyone want to buy a car ? I’m about to set this on fireI think at this point, I would get the column apart.
