3" or 2.5" exhaust (pics)
x-pipe is the only place it will fit. its not on in the pic but the x-pipe is just behind where the driveshaft loop is. oh that x-pipe may not be in the "perfect" location but it definatley works. had to go up two jet sizes after that went on.
do you have a welder? personally id run 3". if you ru nan X pipe it should be the same diameter as the collector, neck it down after the x junction. if you have a mig, the 45* pipes that come out of the X, pie cut the side of them and squeeze it down to 2.5" and weld it up, or just use some reducers.
