3 Questions - Steering Column, Steering Gear, & K- Member
marianamaya
bloomfield hills, 48302
1. How can I confirm that the K-Member that I have is correct for a V8? (Car had no engine when I got it)
2. How can I confirm if my steering gear is power or not? Part Number?
3. If my steering gear is manual, and I want to take the car to power steering, will I need a new Steering Column along with the Power Steering Gear?
Thanks,
Pete
Pete, is it possible you can confirm what the heck you're workin on, or do we just guess? I see what appears to be a Dart in your avatar. It would help if you could tell us for sure. Make? Model? Pics of the k frame in question would help.
To figure out the K member go here:
http://www.engine-swaps.com/
the tech page:
http://www.engine-swaps.com/Pages/TechInfo.html#head3
The possibilities you have: (from your avatar I'm assuming not an early A body)
67, either /6 vs V8 of course has different mounts, both 6 and 8 are "biscuit" or "pillow" mounts, and the idler arm only has one bracket, that is a one year idler arm
68--72 same as above except has upper and lower idler arm brackets, that is better design idler arm
73/ later has "spool" engine mounts, a huge improvement
Steering box is easy: Does it have hose fittings? Is it cast iron? If yes it's power
No hose fittings and aluminum box means manual
There is (and parts could be switched year to year) a "large spline" and "small spline" steering boxes.
NOTE!!!
The center link / idler arm / pitman arm / box all have to "match" Go here:
http://www.forabodiesonly.com/mopar/showthread.php?t=236925
http://www.forabodiesonly.com/mopar/showthread.php?p=1970108152
http://www.forabodiesonly.com/mopar/showthread.php?t=248979
http://www.forabodiesonly.com/mopar/showthread.php?p=1969800222
and there's some very good reference material here
http://www.bigblockdart.com/techpages/techindex.shtml
You can check the VIN to see what the car had originally. This is not to say that some enterprising builder didn't swap it out. '67-'76 K-members will cross-fit (with some conditions). Schumacher Creative Services makes conversion kits to make a moot point of this, unless going from V-8 to /6. In general if the mounts look symmetrical, it's a V-8 mount, if the driver's side is offset or jacked up it's probably a /6. A photo would help.
Look at the box. If no hydraulic fittings on it, it's manual. The PS box has a screw-in fitting for the high pressure side and a nipple for the return side.
Right. The PS column is shorter. If you get steering gear from a 73 or later A, you'll need to get the idler, pittman arm, and cross arm. FWIW, I put a cop car box from a Dippy in the Demon. I also needed to put a cross arm, and idler from a '75 (73 & > ) A-body.
Another "gotcha" is headers. Some headers won't fit cars with a PS. RTFP when buying.
