3" Studs and dog dish caps
roughidle
Super Platinum Member
Pennsylvania
Does anyone make a dog dish cap that will work with 3" wheel studs? I have steel wheels and 3" studs, but I'm curious if anyone makes a cap that will clear the studs. I'm assuming the stock caps will not clear but haven't a set to try. Anyone have any info on existing combinations that will work?
Thanks
Did you get an answer if dog dish hubcaps work with a 3'' stud? I'm curious as well.
genuine Mopar steelies, ramchargers on the back, 67 barracuda caps, stock, and three inch studs all around. Red stripe dodge work too.
The 62 Plymouth looks so good! Thanks for the answer. My plan is to run red line Dodge dog dish hubcaps and body colored steel rims.
