jrlegacy23
68 Barracuda
I have a set of 30 Spline, Dana 60 axles with green bearings and 3" screw in studs installed. The axles are for 54.625" wide Dana 60 with a stock pinion offset (drivers side 1.375" longer), from wheel mounting surface to wheel mounting surface.
THESE AXLES WILL NOT FIT ANY STOCK WIDTH HOUSINGS AT ALL.
As per Doctordiff, these axles have enough splines to be cut down, on a chopsaw to as short as a 50" wide rear.
The axles will work with an 8 3/4 rear if you cut the longer axle down 1.375", or center the pinion and use as is without cutting. Everything is new and never installed on anything. I bought the axles from doctordiff for $325 plus shipping
I am asking $250 shipped to your door in the lower 48 states. I will ship to Canada, but there may be an extra charge on shipping.
I am located near Cooperstown, NY 13326
PM me
PM me
