1967DartGT
Hello all,
I've been reading posts on this website for quite some time and finally joined today. I'm sure I'll have alot of questions to come, but for now I have a couple of questions regarding 302 heads.
First, I've seen flow numbers for 302 heads as cast and fully ported, but I was wondering how much flow increase I might expect with a simple multi-angle valve job and back cut valves? I'll probably stay with stock sized valves to keep port velocity up since the heads will be used on the 273 that came with the car.
Second, if I want to gasket match the ports, should I match to a 273/318 gasket or should I match to a 360 gasket?
I anticipate a mild build with between 9:1 and 10:1 compression and using one of these 3 cams from Comp Cams:
XE256H
XE262H
XE268H
Thanks,
Kevin
XE256H
XE262H
XE268H
Thanks,
Kevin
