RAMM
At long last I was able to set aside some time to test the 347 that has been together for almost 10 months now. Here's a link to bring you up to speed on what I started a long time ago...http://www.forabodiesonly.com/mopar/showthread.php?t=211501
So instead of the roller cam I went with a Lunati Voodoo 60401 it is a flat tappet hydraulic that is a really nice and mild grind. The engine fired up within the first 2 revolutions and breakin went without a hitch. The engine idles at about 15" of vaccuum and is quite responsive for such a low compression combo. The '302 heads did exactly what I wanted them to do and that was function in the 300-350hp range on 87 octane and with minimal ignition lead. A few tests quickly revealed that 31 degrees total was the sweet spot. As you can see it made about 350 ft/lbs just about forever and peaked at about 310-315 hp @ 5300rpm. This was on Esso 87. Sometimes it is nice testing such a mild and forgiving engine.
Final thoughts: I really wanted this engine to be a go anywhere-toss the keys to my wife and come close to 20 mpg with a nice small block that could still turn the tires or merge effortlessly with traffic, (and not blow up the 5spd out the Dakota behind it). I think it will fulfill this role nicely.
'302 heads are NO match for even stock Magnum heads, unless somebody really really wanted them and could not get Magnums then I wouldn't use them.
The Offy 360 is killing HP and TQ, I am confident 30-40 ft/lbs and HP are a manifold swap away.
A little more cam could help but this isn't the cork. Magnum heads and an RPM intake would get this particular engine somewhere in the 360-380 hp and 400 ft/lb range pretty easily--Would I do it? Not just yet.
All in all I am pleased with an engine that doesn't leak a drop,no smoke, smooth idle, starts at the thought of starting it and rev's nice and clean with no drama. In fact I have someone who may want this one for a Dart originally powered by a dead 273--should be quite a bit different. Here's a blurry pic--sorry. J.Rob
