318/904 Kickdown Linkage
ram250098
69 Barracuda
Cookstown Ontario Canada
Would anyone have a pic of the set up for a edelbrock carb kickdown linkage with the linkage adapter, I can't figure out the routing.
Thanks
I have the Edelbrock 1406 on a 318/904 combo as well. I couldn't get the stock kickdown linkage to work very well at all. It was monkey-rigged together at best. Anyway, I ended up using the Lokar setup. I am very pleased with it. Works way better than the old one ever did.
I used the stock throttle cable but would like to switch it out to Lokar as well. I suppose I could snap a picture tonight if that would help. Yes?
Okay, this is how I have mine set up with the stock throttle cable and Lokar kickdown linkage. Pardon the dirty motor, it's a daily driver.
70GT, in your first and third pics, the bracket from the manifold holding the throttle and kickdown cables, was that the original bracket? was original carb 2 or 4 bbl? Also, where'd you find a 3/4" - 3/4" fitting for the water pump to intake manifold hose? Thanks!
