dirty white boy
50 yr old Juvenal delinquent
shadydell claimed 240s, so did hotrods junkyard jewell...Anybody flow 302's and then upped the valve size?
Why not?? The centerline spacing of valve stems is the same on all small block heads; no reason why they wouldn't fit
I'm no engine builder or machinist, but I have NEVER seen or heard 2.02 in 302's in any thread here??
see post 17 on 1st page of this thread!I'm not saying it cant be done but show me a set. Maybe Im lacking the creative mind I guess.
Sorry it takes me so long to respond, I just got this damn phone, trying to figure it out, I’m an old fella (53). I just put up two pictures of 302 heads, one is a stock valve and the other is the 2.02. I have a couple of sets on the shelf.
There is quite a difference, the same shop that did these Heads also did the heads in my 70’ 340 four speed dart. They are very familiar with these heads and valve sizes.
I have heard a lot of good and some bad things about these heads, so I decided to give em a good honest test. That is why I ask all of you, to see what the majority would say. My son and I appreciate all the input that we have gotten. We are going to install this in my 89’ Shelby Dakota, View attachment 1715608823 View attachment 1715608824 I bought it without an engine, so we decided to put this in it and see how it runs. Any input we get is greatly appreciated, someone else’s experience is priceless. Thanks again
I'm bettin those ain't 2.02s.
Could it be we are used to seeing 2.02's with 1.60's ? Less gap, but he could have 2.02's with 1.50's. Won't know till he measures.....Morning everyone, I will put a caliper on them tomorrow, if it is a 1.88, I will ask my buddy why he didn’t put the 2.02’s in the heads. We trade a lot of labor, I do paint and body work, he runs a machine shop. He is way more knowledgeable about that area then I am, I will let y’all know what he tells me.
Thanks again to everyone
Home porting works on 302 heads. Most any head can be home ported, but a person has to understand the design of the port and work accordinglyThing is...on these heads, the 2.02's aren't gonna gain one blessed thing over 1.88's. They don't do a heckuva lot on 340/360 heads unless you zing it over 5 or 6K rpm's regularly. @318willrun ...does your socket and screwdriver method of porting work on the 302 heads like it does the earlier 318 heads? Asking for a friend!
Post #1 OP states 2.02 & 1.60Could it be we are used to seeing 2.02's with 1.60's ? Less gap, but he could have 2.02's with 1.50's. Won't know till he measures.....
Hello, I am building a 90' 318 to go into a Dakota. It is a stock new short block. I have a set of stock 714 heads, and a built set of 302, the 302's have been completely worked. including, 2.02, 160 valves, ported and polished, and new spring for a Comp Cams CL-20-212-2. This is just a mild cam.
My question is will the 302 heads work with this stock short block. It will have an Eddy performer and 650cfm carb. Any information would be greatly appreciated, Thanks
doesn't look right.... 1.88 with 1.60 or 2.02 with 1.50 would be my guessing by the eye ball... LOLPost #1 OP states 2.02 & 1.60
I agree, that's what he says it has though. I would bet once he puts a mic on them they'll be 1.88 & 1.60.doesn't look right.... 1.88 with 1.60 or 2.02 with 1.50 would be my guessing by the eye ball... LOL
Frankly, I’d rather have the 1.88’s in them.
Red area you circled? I don't see it.After looking again closely, it's possible those are 2.02s. Look at the red area I circled. Now compare that to the head with the stock valves. Clearly the head with the larger valves has had the chamber cut in that area. It's a tricky picture to judge for sure. Just might be 2.02 and 1.50 but boy that would be a mismatch for those heads, IMO.
