The cam that the op listed most likely doesn't have this rpm capability and he didn't mention which intake manifold that he's using. If he's going for street performance I think that he would be better off with the cylinder heads he has now and clean up the bowl area, good competition valve job. Guys say that the heads can be milled 0.040" to help with the compression loss,and some have suggested to run aftermarket pistons at zero deck height, this could require a cut of 0.012". All of the 318's that I've dealt with had blind cylinder head bolt holes, so with a total of 0.052" being removed wouldn't this cause the cylinder head bolts to be " to short"? I've known guys personally that have ran 360 heads on their 318's only to hurt performance. And don't forget that the intake side of the heads have to be machined as well in order to maintain proper port alignment. Attention to every aspect of the build has to be taken into consideration.
