that's 2 out of 3, don't forget the very low compression. this can be easily fixed with pistons though, keith black (kb167) are about the tallest available from memory.Hopefully should wake it up a bit as it's the heads and cam that let it down now.
Thanks
I like the 256 XE better than the 262 XE here, too. It’s on par with the Lunati voodoo 258/265 (213/220) in post number 11. Either of those grinds will really add some grunt from idle into the mid range. By virtue of the four speed, even a comp 218/.450 268 high energy would work decently, but would be close to the largest hydraulic cam I would use…post # 18 is a good cam
I like the xe 256H 212 218 @50 447 454 lift 110/106
the tighter lsa will help low end
I wouldn’t worry about the big lift on a comp cam… within 500 miles half the lobes will have .250 lift….510 lift is pretty aggressive for a 318 if otherwise stock.
Likely will need machine work on the spring seats.
Power band will be in the high RPM range.
218@50 454 lift is in my 105k mile virgin 68 340 legit 9.99 to 1 manifolds stealth 650 dp 3.91I like the 256 XE better than the 262 XE here, too. It’s on par with the Lunati voodoo 258/265 (213/220) in post number 11. Either of those grinds will really add some grunt from idle into the mid range. By virtue of the four speed, even a comp 218/.450 268 high energy would work decently, but
About the same as new.Interesting idea.
What does that cost?
thats what im doing with my 85 roller cam 318! thay gotta lil bit tighter chamber thats better and gives a lil more compression than the 302s!I wouldn't go with 302, the slight gain of cr ain't worth time and money, I'd grab a set of replacement Magnum heads instead. Probably add 30-40 hp on the combo I posted above.
I ran a set of 302 castings (1.88/1.60) with a [email protected] hydraulic cam. Had 10hg at idle! Heads can’t flow the bigger valves well. Small motor/small valve dia=port velocity. Look at lunati voodo cam ending in 701.Hey peeps!
Anyone ever run one of these? On their 318?
Been offered one of these
COMP Cams 20-225-4 COMP Cams Xtreme Energy Camshafts | Summit Racing
1970 318 V8 stock bottom end
Eddie performer intake
Eddie 650 thunder
Hooker headers
Dual cross pipe exhaust.
4 speed
Currently has standard 318 heads but when this cam goes in it will have something different
Maybe some 302 castings or the older 273 closed chamber heads to help bump compression. Ported to match. And maybe the 1.88 valves too.
What you reckon on cam choice? Car is NOT a daily, and only a very occasional strip car. mainly a street driven toy.
Thanks
With valve "notch" pistons..I mean.275deh is a good cam, Strong mith range.
Go for..
Stock 360 1.88 and flat top deck pistons.
Have that cam in a 360..
Performer intake,
Carb holley 600 vacuum,
Summit 1.5/8 headers.
Stock comp.
That cam going to have a little rough idle in a 318.
Whiplash cams are all about sound. Not much power over 2000 r's or so.Was also thinking 273 heads for the same closed chambers and generous ports.
Might be a little easier to find here as well.
Will keep an eye out for one of those lunati cams. Also heard good things about Hughes whiplash
That is not really true it pumps up the low end with the tight lsa for low comp engines
This guy runs 13.20s street tires low comp 340 whiplash 3.91s
He ended in the 11s with a stroker
The whiplash works as intended
the cam you listed is 4k to 7000 no low end in 318Low end to mid range is what I'm after in a street car. I want that gut kick in the back more then I want a screaming 0-100mph car.
The thought of smashing my way through gears to 90mph in London with 1970 brakes makes me feel uneasy
