318 electronic distributor
vitamindart
Vernon,Wisconsin
ok, so here is my dilemma. I have a 95 magnum 318 in my valiant.
currently running a MSD dist & 6AL box. I have persistent miss that wont go away.
pretty sure its Ignition related as I can occasionally even catch it on my timing light.
I have changed the plugs, wires, cap & rotor with Zero change. not sure if it is in the box or distributor ( both were purchased used ). I am looking to swap or replace both.
I know they are Both overkill for what I need. The car is just a cruiser and I want something reliable and affordable that I can easily get parts for.
should I just get a stock remain distributor and run a gm hei module?
or are the skip white? distributors decent? or the proform?
if possible I would like to have HEI terminals on the cap ( I did see summit sells a cap for the stock dist that has these )
Thanks!
Check the reluctor gap yet?
You can get male terminal caps all over the place.
I think I checked that when I converted it back to mechanical advance.
the previous owner had it locked out. it doesn't have a vacuum advance, I was thinking that would help my mileage & drivability since its a cruiser. figured I could save this stuff for a later build.
I would risk $45 on a Skip White distributor, and it normally comes with the male connectors on the cap, as you desire. For any ignition, insure you have a solid ground connection, i.e. not a rusty screw.
Yep.
I think the skip white distributors are totally worth the cost for ignition electronics, if a person isn't picky about OEM.
Heck a red male terminal HEI cap will almost cost that by itself.
So where do I get that dizzy?
I just checked out Skip White Performance and the only MOPAR I saw was a billet pro, no vac, and requires CDI with an external coil.
Oh and it was listed for $54.50.
Do they have 'Normal' ones?
sorry, I guess the ready to run ones I saw on ebay are not skip white.
but for 50 bucks I might have to try one out.
does anyone know if It is possible to use the GM module instead of or in place of the cdi box?
Free shipping from Speedmaster at$57
http://store.speedmaster79.com/p-46...-coil-hei-electronic-distributor-red-cap.aspx
