Have you checked the point dwell?
I cant keep it running to get a running point dwell. But I just tried to grab one by simply turning it over without the rotor on it. I don't know how accurate that would be but it sure did fluctuate. Started at 40 degrees, dropped to 30 degrees (was set at), jumped back to 35 degrees.
Then get the distributor cam on the high point and measure the point gap with a feeler gauge. Should be like .019" - .022" Make sure the screws securing the points are not loose, first.I cant keep it running to get a running point dwell. But I just tried to grab one by simply turning it over without the rotor on it. I don't know how accurate that would be but it sure did fluctuate. Started at 40 degrees, dropped to 30 degrees (was set at), jumped back to 35 degrees.
What is on the rubbing block of the points? In the picture it looks fuzzy. Grease?
Bad points condenser.
I'm in this camp. Maybe a ballast issue also? How do the point contact pads look?
Owwwwch....69,
I hope for your sake it is points/cond. A simple fix.
However, seeing the engine has 700 miles on it, I am wondering about the dreaded lobe/lifter failure scenario....
The carb has 700 miles on it, the distributor has about 300 miles on it.69,
Good for you! Remember: go back to the basics and never overlook the obvious. I hope your new condenser is a good one. Many new ones aren't.It's alive, it's alive! Points and condenser. Running like a charm. Very busy last two days and got back to it this morning. I checked the points gap and it was good, however the points seemed to have an arcing mark on them (pic in post #18). In the end I believe it was a bad condenser, but because I changed them both at the same time I can't be guaranteed. I think the key info was the backfire symptom, a tell tale sign I have unexploded gas leaving the cylinder (intermittent spark).
Thanks to all for your help.
Why not? Points do work. I even upgraded Vixen to a nice electronic ignition not too long ago. Points ran fine, but I already had the electronic distributor which I rebuilt and recurved and I also had the harness. All I lacked was the ECU and I got one and did it. Runs good.Triple R is probably not going to agree with me, Lol. But in my opinion, now's the time for an electronic ignition upgrade. Easy Pezy. Give that points distributor to your 3rd Cousin. .
