Here's a link to Hot Rod magazines "Junkyard Jewel" build. 400 Horse 318.
http://www.hotrod.com/howto/113_0304_318_small_block_build/index.html
Here is a link to Hot Rod magazines "Junkyard Jewel" build. 400 horse 318.
It's another good read.
Hot Rod magazine's "Junkyard Jewel" 318 made 406 horse and 408 ft pounds.
Not bad at a cost of $1,466.83.
Link
www.hotrod.com/howto/113_0304_318_small_block_build/dyno.html
Link
ADD anyone?
ADD anyone?
Ya,but how long did it stay together??...not long they put a 125 shot on it and "boom".....waste of money!!! well maybe not it was only a 318...
haha nice azzhat. thats the prob with the some in the MoPar world.. to many haters.:thebirdm:this is a Mopars only forum. i hope you get kicked out.
318s can make either good daily drivers or sub 11 second motors. everyone doubt the potential of a 318. its just a 318. well people build motors that are just 340s that kick big block *** all day. same with 318s. you dont even have your motor in the right make of car. what the hell is this?? is treason not punishable?
I guy I know is finishing up his Scamp with a 351 ford in it. I promise it will kick 99.8% of
318 Butts out there lol.
have a great day.
now when GM finally does buyout Chrysler.. I'll still Love yah. :-D
anyways..
300,400 hp 318s can be done. NOT easily tho, for those who think it is, keep dreaming.
but i suppose with enuff $$$ 318 could be king. super/turbocharging is ur best bet.
cheers
PS
have a great day.
read it? up. do i believe it? up. are they tellin yah everything? hell no. otherwise EVERYBODYI wouldn't be so sure. Did you even bother to read the article? The basically made a 400 hp 318 for about $1500. Doesn't seem like a lot to me, and they were still using mopar heads. 30 cubes isn't that big of a difference. Besides, now your buddy has a cross-breed, which means custom parts. Mopar or brand-X, cross-breeds of any make aren't the way to go.Ford's should be ford's, chevy's should be chevy's and mope's should stay mope's. For the time/money he spent putting the 351 in the Scamp he probably could have built a 318 that would be faster. You can't pretend that 351's don't have their own share of problems.
would have 400hp, $1500 318s. I also realize every engine has there design flaws (except mabey
for Ferrari lol). mopar engine/mopar body is fine and dandy for most, but not for others.
IMO the best money spent would be to SC the 318.
cheers
Here's another thing:
http://www.moparmusclemagazine.com/techarticles/mopp_0409_318_engine_build/dyno_testing.html
In this article, they hit 400 hp with a 318 also, but they have a fresh bottom end with zero deck pistons, a windage tray, TTI headers, Magnum heads, and a single plane intake. The cam is slightly smaller however.
Maybe the guys at Mopar Muscle aren't as good as the guys at Hot Rod?
Or maybe one (or both) of them is BSing.
The fresh bottom end doesn't really make any hp, and the zero deck pistons just set the compression ratio up with the magnum heads.The hot rod guys set their compression up by milling the heads instead. The TTI headers are nice and expensive, and if you were running this engine in a car would last a lot longer, but on the dyno stand aren't necessary. Maybe buys a little hp, but so does a bigger cam. And the bolted on magnum heads had smaller valves (1.92 vs 2.02) than the 302's in the other article.
Both the 318's had a claimed 10:1 compression ratio. HR had bigger valves and probably had better head flow numbers to go with, ran a bigger cam, crappy headers, and a 650 double pumper. MM ran a smaller cam and heads, better headers, a single plane instead of an air gap (which they said was a good alternative), and a windage tray with a new bottom end, and a 750 double pumper.
The HR build has a head flow and cam advantage, but loses on the carb, headers, and windage. The MM build gives up a little head flow and cam, but runs a larger carb, intake and headers, and takes care of windage. I don't see why both these engines can't make about the same hp, especially given different dyno's, which we all know makes a huge difference. MM definitely spent more money, and would have a better base for a reliable engine, but either way you've got a 318 in the 400 hp ballpark.
The key to a killer 318 like any build are the heads.Like uncle ted stated here is an excellent write up on a 477hp iron magnum headed 318. http://www.popularhotrodding.com/tech/0901phr_mopar_318_magnum_engine/index.html
Oldschoolcuda
