[SOLD] 318 Fresh Motor
Dartn440
Southern Pines, NC
1966 cast date LA 318, .040 cylinder bore. Fresh 360 heads. 9.0 compression according to machine shop, balanced assembly. Crank turned .010. Performance 318/360 intake,Rebuilt Holley 650. Comp cams .488 lift cam. I’ll have to go back and get the grind for you. New rings, bearings, filter, pump, fan, alt, etc. Nut ton of money in this. Was going in a truck, but truck deal fell through. Drop in ready, Need gone. Can get a price on 727 or 904 for buyer if needed. Can ship on buyer’s dime. Local pick up ok. Asking $5000 obro. Partial trades ok on mopar projects.
A few questions I'm sure others would like to know:
Did you bore the engine .040 or it was already?
What piston manufacture and part # are in the motor now?
Rings used: file fit? Moly coated?
Camshaft manufacturer and part #?
Cam degreed? at what centerline?
Timing chain manufacture and part#?
High volume oil pump or standard?
Not questioning your build ability, that is proven. Just would like more details on the build for $4800
Thanks in advance
