A lot of work was done on 'big block' heads in the 70s with stock ports and iron intakes!
Most of the improvements were valve head angles and mostly seat angles...
This would infer that cam choice and initial flow through the port was critical.
Clearance around the valve heads in the first 100 thou of lift, is very important indeed...
