318 heads
Mister Twister
FL
Has anyone put larger valves in this head? How big can I go do you know? Thanks in advance.
You'd probably want to keep it to 1.88/1.60 valves since the ports won't flow enough for 2.02's anyway.
Thanks for the feed back. We have went with the 1.88/1.60 valve size Cathi should be starting her port work soon. Don
A lot depends on the year of the 318 heads. I had a 74 318 motor and those heads are bad ***.
Why bother go get a set of 340/360 heads and go from there 318 heads have little dinky ports compared to the 340/360 head so you'll already be ahead in the game..
LOL, could be a money issue and/or a class rule issue. The head can be ported out preety good and the windows opened up preety large.
You can put as large as 2.05/1.60 in it. The "why" question comes up tho. As noted... the ports can't support that size valve well. 1.88/1.60s are prob the best all around choice. 2.02s are ok but there should be some serious work to make them really viable.
