318 Intake Manifold Question
74dart
Colville
Hello, I am working on a 74 dart with a 318, AFB Weber carb and I am having performance issues and some stalling.
I have done some reading and maybe I am using the intake for a TQ or Quadra-jet and does it cause a problem and how can I fix it? The secondaries look pretty large to me.
Here is a picture of my intake.
I do remember there was a spacer on it before I did the rebuild. I guess I removed it without thinking it was important.
Yep, you have a square bore on a spreadbore intake. The plate will cover the rounded portion of the secondary holes in the intake and eliminate a vacuum leak there.
That's probably what's happening, you have a vacuum leak.
Does the gasket go down on the manifold before the spacer plate?
