JeffreyLee
1965 Barracuda
I am beginning re-assembly of my 318 LA motor. The fel-pro gasket set has what appears to be 2 sets of oil pan to timing cover gaskets....I assume one for the older and another for the newer 318's. I cant find a video describing installation of the older style front and rear gaskets. Do I simply apply a generous bead of the black RTV in the image to the underside of the rubber gasket when I install? I suppose the nubs on the gasket are just for alignment and get cut off when you are cinched down. Yes? Also a side note, should I paint my oil pan engine color or black? Just a preference? Thanks in advance.
