I assume you mean the aluminum finned style? I think they should fit just fine if you have a stock intake manifold. Otherwise, you may have to grind a little off the bottom lip where the intake meets the covers, easy fix and very common on SB Mopar angines, Thicker gaskets may help to. You will also have to run a different breather cap and PCV valce, your 273 ones won't work, they have a stove pipe style, You will need a newer style rubber grommet and PCV valve (all easy to get)
