carter are not mechanical...the throttle blades do open with the linkage..but the air valve does not open until the flow is high enough...so the carters are more like a vacum carb.
OH MAN! Look at the Carter carb. From underneath, Operate the throttle arm, watch as both primary and secondary sides open when you operate the arm from rest to W.O.T position.
This is called mechanical operation at it fullest. The carb is a mechanicl secondary carb. Period.
Operation of the secondaries are velocity actioned via the air velocity door that is counter weighted on the AFB's, spring loaded on the AVS and T-Q's.
as far as the 318....I would look at the summit brand cam...lifter...timing gears...intake manifold and eddy 600 carb...i would change to electronic ignition..and a good flowing dual exhaust ...with header being an option...
A big thumbs up there. Cheaper brand spanking new parts by Summit.
i got you on the sound but evidently i am missing kickdown cable so no 4 barrel sound
The MoPars use a rod on the tranny for pressure to the internals of the tranny to kick it down, not for 4bbl. operation. If you do not have a kickdown rod on the car, STOP DRIVING THE CAR NOW BEFORE YOU DESTROY THE TRANNY!
The tranny needs this line pressure to operate normally or with performance. Failure to do so will destroy the trans in a few short miles.
Been there done that in less than 20 miles.
Lokar or other such companies have a cable for this issue of missing or custom linkage parts, There easy to instal and set up. Very adjustable.
IF you have an OE carb, beaware that there is no provision for this cable and you'll have to fab up a bracket for there use.
(Yes, I know you have a Holley, just making mention to the other guy that's reading this inthe future.)
Heres a picture of what I did to make it work, nice and easy.
http://www.forabodiesonly.com/mopar/showpost.php?p=91931&postcount=81
