Tbone416
318 Street motor
1985 hydraulic roller cam
302 heads complete valve job
new bottom in with Clevite full Groove bearings and mahle rings
Cast pistons,Mopar cam bearings, seal power lifters, Fel-Pro gaskets,
Champion plugs,brass freeze plugs,new water pump and fuel pump
Mopar performance valve covers. Elderbrock Aluminum Intake.
Wires,cap and rotor. A points or electronic distributor your choice. No carburetor. Can hear run on a test stand.
Guaranteed asking 1200.00
Will convert to a truck motor if you like.
This is the motor that was at Farmington this past weekend
Will install it for a little more coin.
