318 rotating mass
big66440
Anyone know the different weights of cranks/ rods(floating pins) from factory cast or forged pieces I'm trying to set up a very light internally balanced rotating assembly, I have a 318 poly forged crank and rod set up but if I can save weight on eagles SIR I beam rods (605 grams) they're within my budget, redline would be approx 6200 to 6300 RPM N/A, thanx
What hp level? Stock rods will do that too and may be lighter. (not sure...) I run a redone stocker w/good bolts before the SIRs.
The poly 318 uses the lighter '782 rod, which is bushed, so it's easy to remove pistons.
On the pre-'68 engines, the converter hub is smaller and most A/M convertors won't fit, but the crank can be machined for the larger hub.
If you are planning on running a manual trans, the hub size doesn't matter, though.
If you want it as light as possible with stock components, use a cast 318 crank, the weight difference is negligible, but there is a difference, and a Mopar cast crank is more than capable of taking HP and RPMs.
Use the poly pistons with a set of 'J' or '587 heads and your compression will be @ 9.5:1, just be sure to add a notch on the pistons for the exhaust valves.
Don't worry about 2.02 valves, they are unnecessary on a 318, 1.88s will be plenty.
Mark.
