Codybones
I have a 72 Dart with a 318 should I swap to a 340 when a swap the 3 speed on the tree to a 4 speed on the floor?
yes. from the info you posted, yes.
No real goal I’ve just always heard the 318 was a dog, that being said I’m not that concerned with tons of power just a nice runner.Need a little more information
Whats your goals?
Do you have a 340?
iNeed a little more information
Whats your goals?
Do you have a 340?
i dont know much about the 318 I would probably rather pull it and rebuild it and through it back inWhy? You can economically "soup" it up without pulling the engine. Is there anything wrong with the 318?
For your goal, the 318 will be fine. Read anything that you can find on what 318willrun has done with the 318.No real goal I’ve just always heard the 318 was a dog, that being said I’m not that concerned with tons of power just a nice runner.
i
Cubic inches are always better for performance but the 318 is a good engine to build some decent power. Pretty easy to get 1 HP per CI out of any V8 these days.No real goal I’ve just always heard the 318 was a dog, that being said I’m not that concerned with tons of power just a nice runner.
i
A performance 318 just never was offered by the factory, one of the main differences between 318 and 340 is bore size 3.91" vs 4.04" other than piston a 318 can use all the same parts as a 340. A 318 will respond like most engines to a basic hop up, mild cam, 4 bbl, cr, exhaust.No real goal I’ve just always heard the 318 was a dog, that being said I’m not that concerned with tons of power just a nice runner.
340 are hard to find and are expensive the choice is generally between a 318 vs 360 most will say go 360. Either will work especially for mild performance.i
If you have to ask, then yes. Better is a 360; then you can keep the 3-speed, or put an A833overdrive in it.I have a 72 Dart with a 318 should I swap to a 340 when a swap the 3 speed on the tree to a 4 speed on the floor?
Just buy a Chevy. None of the Chevy guys ever talk about their engines being dogs.
The biggest problem I've ever had with a 340 is I've never been able to get my hands on one. theyre made of unobtanium"Do you have a 340 running and ready to drop in?
Is the 318 in good condition?
318 are given the “Dog” moniker because they were often low compression engine (7.8-1) saddled with a lot of emissions devices and low gear ratios, 2bbl carbs and hwy gears. Early 70’s and ‘60’s 328 had a little more compression and work well with small camshafts.
They are very good in obtaining mileage if not given to much cam and gear. AJ/fromS suggested an OD trans which is difficult to come by. But super helpful for mileage concerns. His suggestion of a 360 and I’ll add it in a 5.9 for more power over a 340 is a wise choice since a good running 5.9 will make 300hp with just an intake and headers. You’ll just need to address the balance issue with a proper flywheel or weight on the flywheel.
FWIW, my 5.9 gets only 17 move but it is in a bigger car, a ‘1979 B body Dodge Magnum w/3.55 gears.
If you want to hop up the 318 AND you’re doing a rebuild on it, the only expensive part that differs from the larger engine that is expensive are pistons. So if you go out and get a 340 block, that cost in getting the 340 block alone will be more expensive that the 318 pistons.
