[WANTED] 318 timing chain cover, cast iron.
jobrated_man
1965 Valiant and Dart
San Diego
Rating - 0%
0   0   0
Looking for one of the hi-rise timing covers, used on the 318 in trucks (especially the poly 318) to raise the water pump and fan higher behind the radiator. Usually cast iron. Bolts on same as regular cover, but pump is extended up about 4 inches.
I have a marine 318, has strange front cover, steel not aluminum, water pump mounts like p/s pump and has hoses going to intake, 273 4bbl single plane. I don't know if it is the one you are looking for. post pics if you can.
Thanks. I found one here locally, got it installed on my A-318. I think yours may be a specialized one for marine uses.
