Garage Mechanic Gift for the Gearhead in Your Family!
Small Chrysler
273, 318, 340, 360 A Engines
Firing Order
Cylinder NumberingDistributor Rotation
Clockwise
Torque Specs
These specs may not be correct for your application.
Verify your engine specs with a service manual for your year and model.
always torque bolts in three equal increments
Bolts or PartsLube or SealerTorque to:Main CapsEngine Oil85 ft-lbs.
Warning!!!
If you are using ARP bolts, you MUST use
their specs.
Click Here!Connecting Rod Bolts (Plain)Engine Oil45 ft-lbs.Cylinder Heads
273-318
340-360
Engine oil
(blind hole)
Sealer
(water jacket)
85 ft-lbs.
95 ft-lbs.
Rocker Shaft bracketsEngine Oil17 ft-lbs.Oil Pump CoverEngine Oil95
in-lbs.Oil PumpEngine Oil35 ft-lbs.Oil PanEngine Oil15 ft-lbs.Camshaft Locking BoltThread Locker35 ft-lbs.Front CoverEngine Oil30 ft-lbs.Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer35 ft-lbs.Valve CoverEngine Oil6 ft-lbs.Water PumpNon- Hardening Sealer30 ft-lbs.Fuel PumpEngine Oil30 ft-lbs.Starter mounting BoltsEngine Oil50 ft-lbs.Exhaust ManifoldAnti-Seize Lubricant30 ft-lbs.Spark PlugsNo Lube or Sealer20 ft-lbs.Flexplate/Flywheel
Thread Locker55 ft-lbs.Clutch Housing BoltsEngine Oil30 ft-lbs.Flexplate to Torque ConverterThread Locker270
in-lbs.Centerbolt
(Harmonic Damper)
Engine Oil135 ft-lbs.Bellhousing
(Transmission to Block)
