gold75duster
Member
- Joined
- Mar 28, 2010
- Messages
- 11
- Reaction score
- 0
I have just installed a edelbrock 600 cfm carb and edelbrock intake on a stock 318 75 Duster and am having troubles getting it dialed in.
I am having the car slightly hesitate. It just doesn't seem to be wanting to go like it should.
I tried various timing adjustments and currently have it set at 5 degrees advanced which seems to be were it idles the best. Is anybody running the same or a similar set up that has had better luck with a different timing setting?
I have tried to set the air / fuel mixture but no matter how much I tighten the air / fuel mixture screws on the primaries and secondaries I can't get the motor to stall.
Any ideas? I am at 3500 feet above sea level. Am iI looking at swapping out jets / rods to get this thing to run right.
I am a novice at this so any help would be greatly appreciated.
Thanks
Thanks
