318 Valve Covers ?
toddlaine
Chalmette, La
Looking to get a new set of valve covers. My question is the stock ones I have on have a pcv on one and a vent hooked up to the bottom of the air cleaner on the other. The Mopar Performance ones only has oil caps on both. Can I dis regard the pcv and vent to air cleaner or do I need to add this back. I am switching over to a Edlebrock Carb and Intake at the same time as the valve covers.
Thanks,
i cut out one of the holes and added a grommet and pcv running to my carb on one side and added a breather on the other. you need at least a pcv for proper crankcase ventilation.
