What are your spark plugs Brand/Range...and what are they gapped to? Boost tends to BLOW the spark out under High Load situations.
I recommend nothing but NGK Copper Plugs.
If your plugs are gapped like stock specs....close them up to .028 and report back.
I agree with everyone else....you need less Final Drive Ratio to fully load that bad boy on the big end....mmm SG 3.23's
Good luck.
True, but you'll have to close the plug gap some to make sure that it can still bridge the gap under the higher cylinder pressure with boost. A good coil and ignition box helps curb that problem.A stock ignition will survive 5500 rpm as well as a stock pump. Been there done that.
The springs are more than likely the same chinese **** as the cam so there too could be a problem.
It is still in his best interest to get rid of the 3.91 gear! TOOOO much gear for the turbo!
YES!!! Agreed!More nitrous. Then it will rev.
hmmm...irrelevant advice, or too lazy to pull the plugs and regap them?
I may not be able to figure out how a Tuff Wheel horn button actuates the horn switch, but I KNOW turbocharged engine diag.
