titanium
When buying a 318 is there any one year that is better then the others or what year(s)would be the preferred year(s) over the others?
1972 and older.Dont some of the early la motors have free floating pins.
wouldnt a 360 be a more affordable build?
Sounds like a good deal. Wish I was a little closer. The one I mentioned in my 2nd. post is 45 mins. away.I got one sitting in my carport if you want - it's out of a 84 truck. Never have ran it but
the guy I bought it from was the mechanic that rebuilt it. The only thing I've done with it
is a compression test and it gets 150 in all cylinders. Will let you have it for $100 if you
want to come get it. The only thing I'm going to do with it is take off the Eldenbrok intake and put a 360 stock one on it. Is complete, even has the fan on it. Was going to
put it in my 67 Dart but picked up a 360 in Vermont a month ago and want to go with
that instead.
85-91 Roller Cam 318 with 302' casting cylinder heads=Black Engine OE
Minor SB Upgrade parts...timing chain, HV pump, welded smog ports,..regasket/reseal/new freeze plugs
Air Gap, + 600 cfm edelbrock, + headers, and it would be a Nice pump gas driver/screamer.
