I went parts picken again yesterday and I saw a box full of header elbows .
Not sure what size . You already have what you need ?
I have a few pieces, but I will need more. Primaries are 2".I went parts picken again yesterday and I saw a box full of header elbows .
I haven't started it yet, but it's in the truck and progressing, albeit slowly.So, you ended up using that motor?
Most definitely no one here would turn down that setup if opportunity and price was ideal. You may be only one in the country with that setup in a classic truck?Ok sent me the hdmi. I just got a couple of the Dodge Power Giant
trucks. One is a 58 W300, 4x4 the Hemi will look right at home in it.
Send asap.
A truck setup would certainly have some advantages. Just being full framed from the factory to start. The only clearance issues are probably just stock front inner fenders. Which should have plenty of customizing room. And with the big 4x4 drivetrain options? Should be no problem for even that beast. The only question. Hot rod? Or throwing mud out of a pit run? (Which would be crazy with a classic truck. But crazy gets the crowd.) Lol.Power Giant for 1958
In '58, Dodge re-designed their line-up after only 1 year. Again they were only new from the cowl forward, making a larger engine compartment by enlarging the fenders and hood. The grille for '58 was made of 3 separate horizontal bars identical to the one above the bumper. This was the first year that dual headlights were an option on all models.
1959
This was the last year for the swept side, replaced by the all new swept line bed, the swept side was discontinued in January 1959. A new grille was in order for '59, a 1 piece cross hair grille was installed, while the rest of the fascia stayed the same. New arrows were added to the sides of the hood over the louvers, where a piece of molding had been for '58. The dash was re-designed this year and incorporated a glove box in front of the passenger. New step wells were added to the cab to ease entry and exit of the cab.
1960
This was the last year for the Power-Giants Era. For '60 very little changed, the grille went to a multiple horizontal bar, 1 piece unit. other than that, only the placement of the molding changed.
somewhere between 1959 and 1960, dodge trucks started to be welded in places where they were formerly bolted, such as in the construction of the front fascia. also, it appears that the radiator got thinner, as the top plate between the radiator and the fascia got thicker.
That's completely different. You think a 1000+HP race engine is the match? It would certainly draw a crowd. Lol. But a twin turbo Cummins might do a better job? At 1/2 the cost. With even more torque.This is the same truck as my 58 except mine came with a sprayer tank on it. And mine ain't nearly in that shape.
If I remember right, there is some combo of factory poly block and gen 1 hemi heads that will work together. A 360 hemi would make for an interesting combo for sure.Okay forget that Hemi head question. I think what I'll do is take a 318 poly motor and put a 360 crank and pistons in it. And do a little bit of Port work and bigger valves to the poly heads an a little more cam and try to find a four Barrel or two four barrel manifold for it.
The poly motor is a torque monster so imagine it could move that truck.
That's if I can't get my Hemi from rrr.
here are a few optionsOkay forget that Hemi head question. I think what I'll do is take a 318 poly motor and put a 360 crank and pistons in it. And do a little bit of Port work and bigger valves to the poly heads an a little more cam and try to find a four Barrel or two four barrel manifold for it.
The multiple horizontal bars grill was only on the 1958 Trucks. The 1960 grill had the style shown in your "Grade A Moneysavers" ad picture. Only one single lower horizontal bar.Power Giant for 1958
1959
1960
