Yuuuuuummmm. Sounds like fun.raymond said:Hey Martin, any news on your head flow numbers and your cam specs yet? I'm particularly interested as I have a combo almost identical, .030" over 360, 10.8 compression, custom Bullet hyd / roller cam, ported Eddy heads, 1-3/4" headers, and a much modified LD340 intake and large TQ carb.
'Enquiring minds still want to know these things'
2fine69s said:Raymond,
The engine specs are more mild than you would expect. The heads were only blended and match ported. They flowed: 244 @ 500. The cam is: 224-228 duration @.050. The lift is .540 and .513. Your 360 should make a ton of torque. I built one with a solid roller .575 and .308 advertised duration, and it would blow the tires off at 40 mph.
Martin
