340 Aluminum Edelbrock Heads & Intake Deep corroded Appearance
Swinger Ron
Father/Son - 1970 Dodge Swinger
Ottawa, Ontario, Canada
I bought this beautiful car in the late fall. But as you can see the aluminum heads and intake have a dirty brown look when I bought it. Not sure if it came from heat, oils etc. I would like to clean them without taking the engine out. Any suggestions? Any idea how this came to be?
thanks,
Ron
Just regular old oxidization. Aluminium wheel cleaner. Its an acid. Be carefull around other objects.
thanks,
Ron
To tell you the truth, I wouldn't mess with it myself. It's beautiful just the way it is. Well, maybe put the rest of the air cleaner on it. LOL
Yea that looks like crap. Many ways to clean it but they will never look good again without pulling them and doing it right.
Personally I’d clean as best I could and paint them engine color and be done with it
THIS... I used Eagle-1 Etching Mag Wheel Cleaner, dissolved all the nastiness off my aluminum heads and intake and after rinsing with a pressure washer they looked better than new with a fresh surface for paint to adhere to. I don't have any 'before' photos but they had lots of ugly brown-gray corrosion and oil/dirt on the cast surfaces.
