[SOLD] 340 block, crank heads, 727 trans , 8.25" rear sure grip, v8 k-member
dpmalibu
Hatboro,PA
I just picked up a 73' Dart Sport 340 . Its a basket case so its going to be parted out. Here are whats left of the drivetrain :
This is not the original block to this car. Block needs to be honed due to surface rust in cylinders. It does have new freeze out plugs and cam bearings. bearing have some surface rust from sitting. casting #'s are 2780930-340-5 and date code is 1/12/73 Asking $525 B/O
Stock cast crankshaft from the 340. In very good shape. its wrapped in plastic so there is no rust on journals. $150
"J" casting cylinder heads need to be redone. Heads are clean casting #'s are 3418915-F and 3418915-C $250 B/O
Driver side exhaust manifold from 340 ( original from this car) $70
8.25 rear sure grip w/ 3.23 gears has 86k miles on it. Comes complete drum to drum and e-brake cables. $550
727 trans came out of smae car. has 86k miles on it. Needs to be rebuilt $175
V8 k-member out of same car $150
power steering box $50
drag link $25
original 340 air cleaner base (don't have top) $40
located in Hatboro,Pa
whats the drag link lok;ie and that 8.25 may go in my 65 barracuda nice that cuda not all built to go like a bat out hellwhat axels in it are u will ing to trade
latta mopar parts what u loking for
List Updated:
This is not the original block to this car. Block needs to be honed due to surface rust in cylinders. It does have new freeze out plugs and cam bearings. bearing have some surface rust from sitting. casting #'s are 2780930-340-5 and date code is 1/12/73 Asking $500 B/O
727 trans came out of same car. has 86k miles on it. Needs to be rebuilt $175
List Updated:
This is not the original block to this car. Block needs to be honed due to surface rust in cylinders. It does have new freeze out plugs and cam bearings. bearing have some surface rust from sitting. casting #'s are 2780930-340-5 and date code is 1/12/73 Asking $475 B/O
Stock cast crankshaft from the 340. In very good shape. its wrapped in plastic so there is no rust on journals. $130
"J" casting cylinder heads need to be redone. Heads are clean casting #'s are 3418915-F and 3418915-C $225 B/O
8.25 rear sure grip w/ 3.23 gears has 86k miles on it. Comes complete drum to drum and e-brake cables. $525
727 trans came out of same car. has 86k miles on it. Needs to be rebuilt $150
Rear is sold!!!
This is not the original block to this car. Block needs to be honed due to surface rust in cylinders. It does have new freeze out plugs and cam bearings. bearing have some surface rust from sitting. casting #'s are 2780930-340-5 and date code is 1/12/73 Asking $450
Stock cast crankshaft from the 340. In very good shape. its wrapped in plastic so there is no rust on journals. $125
"J" casting cylinder heads need to be redone. Heads are clean casting #'s are 3418915-F and 3418915-C $200
original 340 air cleaner base (don't have top) $30
lowered a couple of prices
This is not the original block to this car. Block needs to be honed due to surface rust in cylinders. It does have new freeze out plugs and cam bearings. bearing have some surface rust from sitting. casting #'s are 2780930-340-5 and date code is 1/12/73 Asking $425
727 trans came out of same car. has 86k miles on it. Needs to be rebuilt $125
Make me an offer.
Lowered prices to my rock bottom prices. need this stuff gone. No negotiating this is it:
Block needs to be honed due to surface rust in cylinders. It does have new freeze out plugs and cam bearings. bearing have some surface rust from sitting. casting #'s are 2780930-340-5 and date code is 1/12/73 $350
Stock cast crankshaft from the 340. In very good shape. its wrapped in plastic so there is no rust on journals. $100
"J" casting cylinder heads need to be redone. Heads are clean casting #'s are 3418915-F and 3418915-C $150
727 trans came out of same car. has 86k miles on it. Needs to be rebuilt $75
original 340 air cleaner base (don't have top) $20
