340 Cam Comparison
Based on the info I am getting. An XE262 won't work in a stock '70 340.
if I'm looking at the correct cam, the powerband is 1,300-5,600. That's no drag racing cam so it should work just fine in your 340
That's the one. 9.72 SCR brings me to around 8 DCR. I understand that's too much for pump gas. My plan was to build a punchy street engine. Auto with 3.23's. I have a voo doo 268 as well, but the intake valve closing on that one seems less than the xe262 which again raises my DCR.
I'm running a low lift (.421/.443), low overlap, low duration (204/214 @ .050) Erson RV cam with 9.8:1 CR, just use a 30% ethanol mix and you should he just fine
What does this mean?
E30 (30% Ethanol fuel) is a dirt cheap version of 93 octane fuel. It's a 3:1 ratio of E15 (standard pump gas) and E85. 3 gallons of E15 (standard pump gas) to 1 gallon of E85. This will help avoid knock that you would otherwise get with high CR engines that feature a low lift/duration cam
I don't even know if we have that here?...87, 89, 91 (91 supposed to be E free).
E30 (30% Ethanol fuel) is a dirt cheap version of 93 octane fuel. It's a 3:1 ratio of E15 (standard pump gas) and E85. 3 gallons of E15 (standard pump gas) to 1 gallon of E85. This will help avoid knock that you would otherwise get with high CR engines that feature a low lift/duration cam such as the one you
Do a 1:3 ratio then. 1 gallon 87 to 3 gallons of 91
Actually that made no sense on my half. Just run straight 91
So, in your opinion, the engine will run fine with 9.72 static, xe262, and 91 octane?
I would say so. My combo is that aforementioned RV cam advanced 7 degrees with higher compression. It has a lot of knock variables in it but with a little advanced timing and some higher than pump gas octane fuel and it runs like a raped ape
