1969GTS340
I'll bring it up again. Wiped cam? Have you rechecked your lash?
Sorry, I did see your note on that earlier but got side tracked here. I did inspect the lobs when I replaced the intake gasket. They all appeared to be like new. No sign of being worn that i could see. I used lots of Lucas assembly lube originally and I coated the cam again before putting the intake back on. I rechecked the lash at that point and looked closely at the rockers movement. Did not see any of them with less movement. I guess I could put a dial indicator on them to verify.
