71DodgeDemon340
Ive searched and found anything from 17 ft lbs to 20 ft lbs, i know either should be fine but which one should i use. Im using grade 8 bolts and advised torque is 25 dry and lubricated is 18 ft lbs.
Also the pulley has one hole that is slotted, does this have to be positioned in a particular spot? It seems the pulley holes line up no matter how the pulley is oriented so whats the slot for?
