[SOLD] 340 Driver's LARGE HOLE Exhaust Manifold
Treblig
South Texas
From Corpus Christi, Tex....I have a Driver's side 340 exhaust manifold, unfortunately it has a small crack on one of the ears. Overall the manifold is in nice shape and if you can weld cast iron or know someone who can then this would be a good buy!! The ear where the crack is located is still attached by solid metal so it would be easier to weld than a piece that was completely broken off. I need to get $175 plus shipping. MORE PICS ON REQUEST!!
Treblig
PRICE REDUCTION........$165. This is a nice manifold if you can weld cast iron or know somebody who can weld then this would make a great part for your car.
Treblig
Mopar made two different sizes (exit hole) of 340 exhaust manifolds. Some 340 manifolds are 1 7/8" exit hole and some are 2 1/4". The Large hole (2 1/4" outlet) manifolds flow much better than the small hole.
Mopar also made an even smaller exit hole manifold for the 273/318, it came with a 1 5/8" exit hole.
treblig
I've read that it will depending on what type of motor mounts you're using but I personally have never had an early A so that I could actually verify it!!
Treblig
