Pabuhr
I have a complete 340 and matching 727 transmission. It runs great. Includes everything but the carb. Air cleaner, correct exhaust manifolds, kick down linkage, etc. the block is a June 1968 and the heads are J castings. You can hear it run and drive. Great oil pressure and cooling system holds pressure. Come listen to it run and if you like it, give me 2 hours and I will have it loaded into your truck.
Asking $2400.00 for everything.
Located in N.E. Iowa.
