plumkrazee70
FIRST thing to do is get a manual oil pressure gauge and replace that one and see if it does the same thing. If it does you have bearing issues.
10-4
Alright everyone. Check this out
I started it up on the ground with the driveline back in and sure enough, the driveline sound is gone... I was going to take a quick spin around the block, but gun shy when I noticed the oil pressure gauge. To be honest, I've been so focused on the motor, Fitech settings etc, I didn't notice this before. It sure seems it is falling right when the surge happens. Thoughts??
Is the engine rpm jumping around in sync with the oil pressure?I've never had that happen before and since the oil pump is driven from the distributor, it just seemed like a symptom of the problem.
It's a speed hut electric. I thought that also, but all the Guages are daisy chained together with their harness. They get one power and one ground and I'm. It experiencing any other Guages fluctuate like that. (I would think if it's a voltage issue, I would see it elsewhere) I'm getting 14v at idle. I was wondering if something could be a wrong with the oil pump drive or dist. shaft?
erectrics and old cars are a problem waiting to be solved , wires grounds who knows what on a 50 year old car . that is one strange problem , hope it is just electric or gauge problem . Has this engine ever been run as built ? IE carb orig type ignition be nice to know if the engine did run well at one time in it's past . Hope your on the road soon running properly
You could throw the original cam back in and see what happens if it comes down to that...I did watch the video, and at first glance it seemed like an aggressive cam lope, but then I saw that rhythmic vibration pattern...its a stumper for sure.
"Surges" implies a fluctuation in engine rpm.No. The only other symptom is the engine surges or shakes. I'm going to pick up a manual guage tonight to be sure.
I'll stand by the pump relief valve opening and closing. If you had a bad ground the other gauges would also bounce around.
You have other problems to solve first
Take them one at a time, if you make a bunch of changes to quickly you'll never get figured out.
I still want to see the plugs.
Where do the gauges get their power? I wonder if somehow they're interfering with the ignition?
Only shows fire to that plug. If there is some crazy, valve event or some crap, the spark drop would tell ya. Yes, if no change, plug it back, and jump to the next one. Disregard, I didn't read far enough into postCome to think of it. I attached my timing light to each wire and got the spark light. Wouldn't there be nothing if I had a dead cylinder?
Plug #3 looks 'light'. Like it could be getting steam cleaned by coolant. Is it using coolant?
Spark plugs are hard to read due to lack of driving time, but that's OK we can work with what we got here.You're right. I'm getting overwhelmed with my mind going to different possibilities. Here are the pics of the plugs. I took these a few days ago.
That's a lot of double speak man. No offense meant.Not 100% which circuit it is in the EZ wore panel, but it's isolated from the ignition, meaning it's not the same circuit. I believe it's labeled as guage power.
"Not 100% sure" followed closely by "but it's isolated from the ignition".
It's this kinda thinkin that can lead to you forever chasing your tail. VERIFY it. Don't just assume. You obviously have SOMETHING GOING ON SOMEWHERE and this kinda talk and attitude ain't gonna find it. You need to have an open mind to every possibility, or it'll end up someone else's project car when you've had enough.
Now you're talkin. If you can totally disconnect them, that's the ticket. It may not be it, but at least you'll KNOW instead of not knowing. Then, you can mark that off the list.You're right. I can trace back to where they plug in and unplug them and see if anything changes.
