[SOLD] 340 exhaust manifolds
dgswinger
south central pa
here is a matching set of 340 exhaust manifolds correct for the 71-73 and would also be correct for the 74/75 360 A-bodies also. i have decided to run headers instead of these with the new direction i am going with my build. they came off a 73 340 duster. the pass. side still has a short piece of exhaust pipe bolted to it but i will remove it for shipping. manifolds located in south central Pa. 17252
please PM me for exact shipping quote just a heads up most areas in the U.S. will be between $40-$50 for shipping
please look at the pics casting #'s and dates can clearly be seen if someone needs them clarified i will post them.
also heat riser has been removed and plugged , does not leak.
they just need cleaned up and painted
$200 plus shipping
i accept paypal and U.S. postal money orders only
i got my TTI headers so not gonna need these make reasonable offer. also on the bottom pic that is just stuck on gasket NOT a bad sealing surface
