dilley340 Well-Known Member Joined May 22, 2004 Messages 251 Reaction score 8 Location Howell, MI Feb 20, 2009 #1 Do I need the fuel pump eccentric if I'm using an electric fuel pump? I'm getting ready to put the timing chain on.
AdamR Big Member Joined Dec 31, 1969 Messages 17,343 Reaction score 561 Location Bethel, CT Feb 20, 2009 #2 no
R RedFish Well-Known Member Joined Sep 5, 2007 Messages 25,850 Reaction score 5,351 Feb 20, 2009 #3 Why not put the part in there anyway ? If the need to install the mechanic pump should arise it is doable.
waggin moving on ain't easy if you drive a Ford :p Joined Apr 9, 2008 Messages 6,623 Reaction score 435 Location Floral City Florida Feb 20, 2009 #4 you knida need it as a spacer/washer and nice to have it in there in case you go back to mechanical pump......jmo
Demon416 A-Body Joined Feb 3, 2009 Messages 2,357 Reaction score 121 Location WI. Feb 20, 2009 #5 I agree with RedFish and waggin. Install it.
stroked 340 Banned Joined Oct 10, 2008 Messages 3,117 Reaction score 23 Feb 20, 2009 #6 I always wondered the same thing,running an electric fuel pump,but did put it back on my motors thinking it was also a spacer..
Dart-swinger Banned Joined May 26, 2007 Messages 309 Reaction score 2 Feb 21, 2009 #7 You don't have to use it,but I would
dilley340 Well-Known Member Joined May 22, 2004 Messages 251 Reaction score 8 Location Howell, MI Feb 21, 2009 #8 Thank you very much guys! I'll put it on.
M Mopar73340 Well-Known Member Joined Jan 10, 2009 Messages 244 Reaction score 161 Location Northern VA Feb 21, 2009 #9 My 89 360 I took apart a few months ago had one installed from the factory although it wasn't used. I agree it is needed as a spacer anyway so install it.
