superbirdrag
- Joined
- Dec 4, 2005
- Messages
- 138
- Reaction score
- 16
my friend has a 318 with J heads on it . How can you tell if they are 1:88 or 2:02 intake valves with out takeing the heads off .
I don't know if you can.my friend has a 318 with J heads on it . How can you tell if they are 1:88 or 2:02 intake valves with out takeing the heads off .
Yep. If the seats are shot it's easier to go to a bigger valve. 2.08's on a 318 probably not recommended. I know you can have hardened seats installed. I have also seen quite a few fall out and cause a lot of damage.For a performance build, I’d rather start with the 1.88 heads and open them up for bigger valves myself than start with used up factory 2.02 heads.
