cliff guinand
71&72 Cdn 340 Specials
Thanks, that answers a few questions and verifies a few others. Hmmm, but the hunt continues on the 'washer' front...
Let's get more specific. List year, engine, trans, brakes and swaybar then weather or not the k-frame has a washer and let's see where we come out.
1. 71 Demon, 340, 4 spd, disks, NO swaybar and washer.
2. 71 Demon, 340, auto, drums, swaybar and washer.
3. 70 Swinger, 340, 3 spd, disks, swaybar and washer.
I'll have to check my 68 GTS for the washer.
71 Duster, 340, auto, drums, swaybar, NO washer. Built 8/70.
Not original owner so I cannot verify pedigree of X member.
They should have referred to the top K-member here as `68-72. Although the motor mountings may be the same, the idler arm pivot is a different piece on the `67 K-member.
Joe, why are you up so early?
The are talking about measurements to tell the difference between the 6 and v-8 mounts . The idler arm really doesn't make a difference in what they are explaining.
Interesting. Can you verify that it is an original 340 car? Does it have the correct code on the fender or vin tag?
Yes,
Vin: VS29H1B1XXXXX
Fender tag: E55 D32 VS29 H1B 1XXXXX color is EV2
Has a rallye dash with 150 speedometer, shark tooth grill, and rectangular chrome exhaust tips. Interestingly, it is a column shift with a front bench seat.
Current engine is a 318 from 1976 with a 904 trans. No VIN numbers on the block or tranny. History is not availble as to the original engine and trans. I am currently looking to get a 340 for it.
Must have been 70 models and up on the 340's. Don't ya like learnin even at our age?
Here's another one for ya. He's quite sure of this. The steering columns on the 71 and 72 dusters only have the key release knob on the under side of the column. My 72 duster dont have it. What's you guys findings on this one. We looked my field over and i don't have a car that has it in any of those years. This needs some research.
Check this out.
http://www.hamtramck-historical.com...alershipDataBook/1971/71_Valiant_Duster_2.jpg
You posted that your car did not have a sway bar which would have been standard.
Your k-frame may have been changed.
Check this out.
weird. the boxes usually came on 4speed cars..
Hey DFX replying late to this one but is that for sure that only 4 speed cars got torque boxes? My 72 automatic has on all 4 corners and I said the 70 340 4 speed car has on front but might be on all 4 as well. Do we know if they split up with only 2 on the front or 2 on the back? I have seen a couple with only 2.
How about 340 Dusters and Demons (didn't check or ask) - I've only seen them on 340 equipped Swingers.
DFX, torque boxes are sheetmetal boxes that the factory used on Hemi and convertible models (in this case, a select few A-bodies) to strengthen the uni-body design and improve handling (factory subframe connectors). These boxes are located behind the front wheels and in front of the rear wheels and link the rocker panels to the frame. Torque boxes were sometimes installed on 440 cars and were a "hit and miss" add-on, depending on what the factory had in stock on a particular day. Even if your vehicle did not have factory boxes, they can easily be added to your A, B or E body Mopar. There are a number of companies that re-pop them - I got a great set from Rick Kruziger out of WI. I searched here on FABO for a string related to torque boxes but not much. A far as I know, a good number of '70 Swinger 340 cars got them but don't know if any 340 Dusters or Demons got them as well. This also made me raise the question of the washers, maybe they indicated that boxes be added to the car... I think I might start a string asking the A-body torque box question - which cars got them etc.
