PointsOk, distributore is stock, but electronic or points?
I can take a video.
For the "Vehicles don't ping decelerating", why is that? The engine is still firing while decelerating, it's just doing so at a lower RPM. And if the detonation is now occurring at a lower RPM after retarding the timing, I don't see how it's out of the question.
Now I could very well be wrong, and I am not using ex
"One thing to understand is that detonation is not necessarily destructive. Many engines run under light levels of detonation, even moderate levels. Some engines can sustain very long periods of heavy detonation without incurring any damage. If you've driven a car that has a lot of spark advance on the freeway, you'll hear it pinging. It can run that way for thousands and thousands of miles. Detonation is not necessarily destructive. It's not an optimum situation but it is not a guaranteed instant failure."
"The best indication of detonation is the pinging sound that cars, particularly old models, make at low speeds and under load"
Tuning or it's because you're in the big block section.
some good advice here, but may find more in the little engine section.
I'm not sure if you read the entire thread, but I did accidently click 1 thread off of where I meant to click.
Doesn't this mean that when I get off the gas and am coasting at low speed, and am hearing pinging, it is still detonation?
You're cool, I'm just being me. You're in good hands I think the guy's got you covered.I'm not sure if you read the entire thread, but I did accidently click 1 thread off of where I meant to click.
But the people here have been just as helpful as the people in a different size engine thread.
OP - so now comes the unwanted English lesson. What it says is low speed AND under a load, not low speed OR under a load. They mean both things at the same time.Doesn't this mean that when I get off the gas and am coasting at low speed, and am hearing pinging, it is still detonation?
This ^^^^^^^^^^^^^^^^^^ right here.Detonation happens under load. Period
I agree more load gets you closer to conditions that cause ping. So can leaner fuel mixtures. I have never experienced ping when actually "coasting". If what the op describes as coasting is actually coasting it's not likely what he is hearing is pinging.This ^^^^^^^^^^^^^^^^^^ right here.
Pinging while coasting is not combustion related. You have mechanical metallic thingys touching each other. I knew a guy once that thought he had "pinging" while decelerating which is IMPOSSIBLE BTW.....Turned out to be the flex fan just nicking the fan shroud.
As mentioned--cranking compression would tell me all I need to know. I hate threads like this that suck me in and leave me hanging. Lol. J.Rob
That’s exactly what I thought when I read that.It's doing it while decelerating now? Are you sure it's a ping and not a loud exhaust tick from a leak that you are hearing?
I can take a video.
Now I could very well be wrong, and I am not using experience to justify my thoughts, just logic.
Very interesting, thank you for that resource
Yup.Once I see many questions asked and I've asked some too and there are no answers, I mark the thread off my list. I'm glad there's an "ignore thread" option.I hate threads like this that suck me in and leave me hanging. Lol. J.Rob
