TRW used to make a replacement 1968 340 piston that was almost a zero deck. In my motor (340) they sat between .009 and .011 above the decks and yeilded 9.4:1. They are forged though, but I ran them for 13 years and burned the rings off them twice without hurting the pistons. I've also had the KB units and personally I think they suck. Killed two sets in 3 years - burnt the top ring lands off. Detonation problems you say? - With the KB's I'd definitely agree, but I never actually noticed it with the TRW's. If you're looking for pistons for a 360 the KB's get pretty close - I don't remember if I ever actually measured the deck heights. If you're looking for 340 pistons to put in a 360, be careful - I think the pin heights are different in some cases from a 340 to a 360 due to the difference in stroke. Yes, the bores are close and the rods are geometrically the same, but the strokes are a little over a 1/4" apart - 3.31" for the 340 and 3.58" for the 360.
