Yeah but... you're gonna spend $300-400 getting that crank reground. If it were me, id try to just get the block and buy an aftermarket forging 4" stroke. Would cost a bit more initially but you'd be happy with the torque. But that's me.
Fair enough get that baby reground!don't want a stroker.
no idea what i want to do to be honest.Nice score! are you having the short block built to blueprint specs?
Keep this in mind, though. Forged crank ain't an end all be all. Chrysler used nodular cast iron, like Ford and not just grey cast iron like GM for their cast cranks. They are much stronger than people give them credit for. The Chrysler cast cranks will take 500 plus HP properly prepped. So if it's a cast crank engine, all is not lost.ok/ that helps a ton
i agree. plenty of fast 360 motors out there and they never had a steel crank. for what I'm doing I don't need it to be steel.Keep this in mind, though. Forged crank ain't an end all be all. Chrysler used nodular cast iron, like Ford and not just grey cast iron like GM for their cast cranks. They are much stronger than people give them credit for. The Chrysler cast cranks will take 500 plus HP properly prepped. So if it's a cast crank engine, all is not lost.
That's a clear 71 engine. Crank should be forged if it's still the matching one.i picked the motor up tonight. as longs as i measured right its std bore. the rods with no pistons are the original rods. the pistons and rods the seller got from a friend. steel crank drilled for a pilot bearing.. got a windage tray, oil pan and timing cover with it. now i just have have to figure out how to build it. want it to run like a 340 is supposed to and be a nice cruiser with the 3.23 gears that are in the car. I'll use the 340 manifolds i have on the car now along with the performer rpm (non air gap) intake i have. I'll also use one of the sets of J heads i have.
casting date looks to be 1-13-71 or maybe 1-15-71. not sure what the vin is from.
Standard bore 340 block is hard to find. If it is easy 1000 just for the block around here.
These are true for a factory build but who knows what happened afterwards. Block appears a need to be decked. All 340's had the same same casting block, just the internals were different on the low compression ones. Being it needs a total rebuild, why not buy the early parts to bring the compression up to 10.5 - 1 ? Cast or steel crank will work for most builds, unless you are using the button. $300 - $500.00 would be a fair price, without the heads.View attachment 1716029639
These are the factory markings for undersize engine components including crankshaft journals.
I’ve seen a cast February’72 built 340The compression drop and cast crank came in some time around April of 1972, so it's entirely possible it's a forged crank, 10.2:1 motor.
Who in the US is making and selling "cheap" cranks and rods?To know crank diameter, check the bearing markings. StD, +0.010, etc. But I would go with a new complete rotating assembly from a US supplier. Cheap insurance, and the opportunity to select stroke. Many options there. Hard to beat ported X heads if this is what it has, but I do like the weight redeuction of Eddy or TF heads now that they are available. Many advantages to Aluminum heads and weight is the enemy (quoting Mopar Action's Ehrenberger). Even though t 360 is overall a better starting point, I am a 340 person for 54 years. Got my first 340 (and still hae it) in 1969. Raced the snot out of it in SoCal for years and never broke a thing. Ran 13.40's @ 105.38 all the time in stock form. Out pulled a brand new 440+6 Cuda at top end at Irwindale in 1970. That surprised him. He thought I had a Hemi! Jaw dropping moment when he saw the 340.
The last crank I had re-ground was $125, but that was in 2019Yeah but... you're gonna spend $300-400 getting that crank reground. If it were me, id try to just get the block and buy an aftermarket forging 4" stroke. Would cost a bit more initially but you'd be happy with the torque. But that's me.
I recently had it quoted a couple places nearby me for my 360, and they were quoting $350. Prices have gone up a whole bunch in the last few years.The last crank I had re-ground was $125, but that was in 2019
Are the Pistons on the low comp 340 down in the hole like a 318?
Do you mean standard never run or standard with light wear and can be bored .010, .020. .030, .040 etc. I am actually right now assembling my "spare" 340 I had sitting around in pieces for years. amazingly the block has cleaned up nice. I had greased the bores years ago.Standard bore 340 block is hard to find. If it is easy 1000 just for the block around here.
