aeonmcallister
Active Member
For sale 340 short block +
Block stamped 73, fully machined and magnafluxed before assembly.
Bottom end consists of the following
KB243 on stock rods and 69 forged crank fully balanced with summit SFI dampner. all rod and main bearing bolts are ARP.
Cam shaft is Lunati voddoo 60403lk with matching lifters. Timing chain is billet double roller with magnum cam tensioner
Also included is Kevko rear sump oil pan with high volume oil pump and pickup. Pan has built in crank scraper and windage tray
This is the full bottom end, engine only needs heads, intake and ignition to run.
Looking for $2000. Location is DFW, TX area
